Hand Tools
52100 experimentation continues *PIC*
David Weaver
Battling a huge complex migraine yesterday and into today - the noncomplex part usually lasts a few days after the "complicated" part occurs.....
That said, 52100 continues to be a really pleasant surprise - it's relatively easy to work with and get good results and it seems to be very stable in the quench. Its movement would probably be considered a lot for an industrial/machining operation (like boutique manufacturers), but it's a tiny fraction of the amount that files move, and it seems to forge weld pretty easily.
I don't have any chisels cut in the other option, just blanks hammered (that being 26c3, which seemed more necessary to try prior to 52100 turning out better than expected).
The bottom 3 are chisels for me (two tempered back a little bit further) and the top four (two finished, two that need to be finish ground) are set with relatively large bolsters to be used without ferrules. The very narrow chisel (about 0.11) came right out of the quench without any significant warp. With files, it would've been a complete gamble, or beyond a gamble (warping in more than one direction).
Messages In This Thread
same chisels. *PIC*
Re: same chisels.
The reason for the choice...
Re: The reason for the choice...
Better than O1
relying on the charts...
caveat on my sharpening perceptions..
Re: caveat on my sharpening perceptions..
Thanks!
for the non-metal folks..
"through hardening"...
Re: same chisels.
Re: same chisels.
Re: 52100 experimentation continues
These get a trip to the freezer...
Re: These get a trip to the freezer...
if it's like the machine areas...
Maybe toughness *isn't* .....
Re: Maybe toughness *isn't* .....
A stake in the ground is needed
Re: A stake in the ground is needed
There's an absolute property..
optimizing hardness and toughness
Discussion and personal value
now I am confused more
Re: now I am confused more
Re: optimizing hardness and toughness
Thank you for the search results
Testing three chisels..
re-do with one of the (52100) chisels
question
Re: question
26c3 mule...
For those like me unfamiliar with 26c3
Re: For those like me unfamiliar with 26c3
Re: 26c3 mule...
Re: 26c3 mule...
Pictures
pics... *PIC*
(looking back at those four pictures...
When work pressure lets up some,
It'll look the same...
Re: pics...
Re: pics...
Deflecting vs. letting go
I think that's pretty much it...
Re: Deflecting vs. letting go
I didn't check with a metallurgist..
26c3 pictures vs. ward later...
not that much later...the 26c3 *PIC*
Tempered to 380F? *NM*
Re: Tempered to 380F?
and the ward *PIC*
Request
Sure...
Temper temperature...
too much?
Re: Sure... *PIC*
Re: Sure...
David's knife
Re: David's knife
short follow up thought....
Re: short follow up thought....
Re: Sure...
