Hand Tools
Consider fatigue as well
Steve D, CT
You were experimenting with 52100, which is a steel used in ball bearings. It has high fatigue resistance because that is the main failure mode for ball bearings that are properly cared for.
If you take a chisel or plane and make one cut like you would in a test and it doesn't chip, it's probably strong enough. If there is chipping after dovetailing a set of drawers or planing enough to need resharpening it could be fatigue failure.
Stress is force/area and a sharpened edge is approaching zero for an area. The stress at the edge is very high and could cause fatigue at a low number of cycles.
Maybe gathering info on fatigue rating of your materials will give you some insight to your results.
