Hand Tools
Re: Visual difference at the back edge of..
Winston
I don't think that what's shown in the picture is due to slurry. Or, at least, it's not mostly due to slurry.
If the slight difference in reflection were cause mostly by the slurry, then I'd expect it to be consistent all the way across the blade.
But instead, the reflection is more pronounced in the middle of the blade. I think this is because the blade is cambered, and so more wood shavings pass over the middle of the blade, causing more abrasion there.
I'm not saying that the "slurry dulling" can't happen -- but at this point, the convexity on the blade's back due to wear has a greater effect than that. It's possible that over time, as I resharpen this blade with more pressure at the edge, the convexity at the edge will be reduced, and the phenomenon you're describing will become more apparent.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
