Hand Tools
Re: High benches and low benches
David Weaver
watch my hips in this video.
https://youtu.be/D9gkJQE7Bpk?t=1219
They change an inch or two. What changes in the stroke is leaning forward and pushing through the end of the stroke.
I have no clue what people are doing when they drop their hips 8 inches, but they wouldn't be able to do it for two or three hours. This is easy planing wood. If much productivity is to be had, it's not to bear down further when less favorable wood is used, it's to set the plane to make the effort about the same as here.
If someone doesn't dimension wood by hand (and thus get much better at smoothing wood in the penultimate step, which leads to better smoothing), I can't really rely on pictures of what they're doing to understand why planes weren't designed with the handle set in low and upright 150 years ago...or even 75 years ago).
I am 5'9" and my bench top is between 34 and 35 inches.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
