Hand Tools
Re: I'll demonstrate thick sometime ..
David, one area I am interested to hear about from you is a comparison of the #18 and the #62 in regard to effort to push a high cutting angle.
My expectation is that you will find the #62 much easier to push than the #18 ... because the centre of effort will change quite significantly.
The #18 requires that you push down as much as you push forward. The #62 allows one to push from low on the handle, and the force vector is parallel to the bench top and forward.
What I have written about quite extensively in the past is the low centre of effort possible with BU bench planes. This does not include BU block planes since they lack a handle. The issue here is the effort requires to push a BU plane with a high cutting angle. Compared with the same cutting angle in a BD plane, and the same thickness shaving, I think that the BU plane will surprise you :)
http://www.inthewoodshop.com/Commentary/CentreOfEffortPart2.html
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
