Hand Tools
side comment about planing in general..
David Weaver
I don't know what people find useful, and I'm sure the depth that I'm taking and demonstrating in is confusing for some.
That is, if I say - if I can show a tiny thin shaving then the iron will be well set for heavy work (that's true in a plane with a cap iron), it probably doesn't register with most folks. The point in that case is to show sharpness and clearance at the same time. Both are more forgiving with a larger shaving.
If I start talking about generation of tearout, and planing to a mark with a try plane, I really have no clue how many people really find such a thing useful. On the australian forum, the cap iron discussion doesn't get too much traction, and I wonder if that's because if you're using something like interlocked jarrah, you'll get to know your planer well. If the planer does a good job, then the depths where folks are fighting tearout...
....well, will they ever be experienced?
I have no idea. I've stopped telling people they should learn to use the cap iron if they like using steep pitched planes and rarely use them other than to smooth plane. Once the block plane was set really steep, it wasn't unpleasant to use on the bubinga as long as the shaving didn't get thick enough to be hard to bend. dullness appears soon, but it's easy enough to refresh and get past it.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
