Hand Tools
Re: Stanley iron
Stanley iron ()
David Weaver
If the back is prepared without serrations going to the edge, the buffing serrations at the edge should be gone.
No need to do anything with the wire edge on the block plane, it'll just come off just like a chisel.
My 18 irons are made of cheese - they are *really* hard to get off of the irons hand honing just flipping an iron back and forth (which I am generally good at) because even the lightest honing of the bevel side on the washita cuts a little bit more of the edge and prolongs the burr.
It should be really quick to address if you can manage to find PSA roll and a surface to use it on. I've never been too sold on spray adhesive and paper, it never works as well as the psa roll, but have to admit that I can't find any inexpensive PSA roll on amazon right now (if you don't already have it - often there's sungold or some other off brand for about $11 or $12 for a roll, and it's something you'll find a use for sooner or later).
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
