Hand Tools
Re: Rotary tool?
Rotary tool? ()
Mike In Los Angeles
Winston, when you asked if I had a photo of the result I thought you meant after some hollowing and some lapping. Most of the hollowing is quickly removed on the coarse stone. When I hollow it out with the foredom, I’m hoping to just get rid of the belly and not leave a hollow that I’ll reach with future sharpening. So I hollow it real lightly, lap it until the hollow is gone or mostly gone, till I get the feeling I’ll be removing the last of my sanding marks when the edge clears up. Usually all the marks are gone by the time it’s honed. That chisel in the photos was one that still showed some hollowing marks and it wasn’t lapped very well.
I either didn’t get around to finishing it, or I’m reintroducing that back bevel somehow.
The process David describes is probably better, I’ve seen people use a magnet or a loop of frog tape to focus downward pressure on a belly. I’ve also seen people hit an iron with a hammer to work out a belly but that gave me a broken iron. If I didn’t have that foredom tool for my square job I wouldn’t get one. You could do it with sandpaper rubbed on the middle of the blade or a stone or anything.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
