Hand Tools
Re: Side sharpening
Side sharpening ()
Winston
> But getting down to the current matter.....side sharpening avoids running the edge directly into grit or slurry. Should work well for back flattening to the edge.
That may be the case... but I already use side-sharpening for the backs of blades, and I still get the little convex part near the edge. It's possible that it's caused mostly by abrasive wear from the wood shaving. Or, even with side-sharpening, there's still some slurry build-up right near the edge. If it's due to slurry, then oilstones would probably be better for avoiding the tiny convexity. (Of course, we know that a little convexity isn't bad in and of itself! The problem for me is that I think it's getting in the way of clean burr removal on the back side.)
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
