Hand Tools
Re: Some context
Re: Some context ()
Winston
Thanks for the pictures. I tell if there's any hollowing of the back, though. Did you do that to this chisel?
> Still, this edge drama leads me to suspect I’m doing something in my sharpening that’s making it recur, I wonder if this is your case as well? I got the impression that it predates buffing for you? Turning over a blade to flip the burr and having it not flip is something that has driven me crazy, any insight is welcome.
I never used a microscope before doing all this stuff with a buffing wheel, so I can't say for sure whether I had issues with a tiny remaining burr back then. (The stuff I can see with the microscope is much more detailed than what I was able to see previously, with a 30x loupe.) I previously used a bare leather strop after a Shapton Pro 12000 and that improved sharpness a bit (when I used a paper cutting test), which leads me to believe that I wasn't fully removing the burr before.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
