Hand Tools
A failed attempt *PIC*
Winston
I tried using the yellow 5 micron JacksonLea compound (or, as David calls it, yellowcake), and it was a bust.
I used a modern Stanley block plane blade -- not fancy, and probably pretty soft. First I flattened it on a Shapton Pro 1000 and then Sigma Power 6000. (I made sure to dress the stones with a flat diamond plate first.)
Here's what it looked like. There's a visible line where the texture changes. I'm not sure what that is -- maybe where the heat treatment stopped? Interestingly, the side of the blade is darkened, but the dark part goes up another 3/4" or so. Maybe one line is where it was heated, and another was where it was quenched? I don't know.
I had a soft 3" buffing wheel that I charged with the yellow compound, and used it on the blade this way, for a total of probably around 1.5 to 2 minutes.
This is what the blade looked like after.
I apparently got too close to the edge, but it didn't really matter. When worked the blade on the stone again, I found that only a relatively small part of the center was raised enough to avoid the stone. This isn't enough to really improve sharpening time, and I think it would go away pretty quickly because it's quite shallow. This is what it looked like after hitting a Shapton 12k stone (note that the lighting makes the scratches look a lot deeper than they are).
So the 5 micron compound on the soft wheel didn't have enough cutting power to make much of a difference, and the soft wheel didn't let me control the positioning well enough to make a useful ura. Ideally I'd be able to prevent at least 80% of the blade from touching the stone, and hopefully more. This wasn't even close to that. For this to work, I'd need to use something far more aggressive.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
