Hand Tools
Re: Some context
Some context ()
Mike In Los Angeles
Although I’m very tempted to lie, I’m going to admit that my chisel showed the blown edge on the back when I went to take photos for you. This is a beater Marples register chisel I chop with sometimes, I have really aggressive Lily White that I sharpen it on. I was surprised to see the back was so thrashed, it was just the one close at hand.
Still, this edge drama leads me to suspect I’m doing something in my sharpening that’s making it recur, I wonder if this is your case as well? I got the impression that it predates buffing for you? Turning over a blade to flip the burr and having it not flip is something that has driven me crazy, any insight is welcome.
Here’s what I’m using and what it looks like. That rubber block is for cleaning a loaded sanding wheel, I’m not sure what it’s called but that’s what I use.
55665-DF1-C122-417-F-9205-297-AC7616009
1148-CA2-E-72-BD-41-A3-8869-8-E210-D85430-F
796238-FE-4-C7-D-4020-844-A-1-F2-BB692-D62-C
869-DA400-EF4-B-4-C52-9474-2-EF228-CFD577
71-FC96-BD-1486-41-CC-8186-248950-E6-E640
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
