Hand Tools
Some context
Winston
The reason I'm interested in this for plane blades is because I've been trying to buff them (on the bevel side) just a minimal amount, to avoid possible clearance issues with bevel down planes.
However, I've noticed under the scope that sometimes the edges aren't quite uniform after buffing. I think this is because before I go to the buffer, the blade still has some burr hanging on, even after going back and forth a few times with the bevel and back on the Sigma 6000. I think that perhaps the reason that I still have some burr is because of the slight convexity on the back of the blade. An ura on the back of the blade would make it easier to sharpen on stones all the way to edge and get rid of any burr; then I could buff for a small amount of time.
With chisels, I haven't really had issues with this, because an edge that's not perfectly straight doesn't matter as much as it does for a plane, and because chisels can be buffed for longer (resulting in a straighter, more uniform edge) without any real drawbacks.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
