Hand Tools
Re: Initially flat
Something precise. ()
Mike In Los Angeles
Everything I’ve gotten second hand has been bellied on it’s flat face, working out the blown corners takes forever. 80 grit psa on glass seems to be the best for flattening the belly without rolling on it, I saw a youtube video where the guy said “Dont roll on it” but didn’t say how not to. Seemed like a sharp guy.
It’s a big drag to work a back on the 80 grit and see a big belly when I go to the next stone, makes me wonder if I made it worse.
I have a foredom rotary tool for my square job and a ton of Little sanding drums, That’s what I’ve used for micro hollowing chisel backs and it has worked okay just going real light on it and taking the marks off with the India stone until the corners are worked out.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
