Hand Tools
Something precise.
David Weaver
I think if you want to do this without buffing the corners off of a chisel, you'd rather have something like a deburring wheel and some fixture to concentrate the work in a certain spot, with the awareness that a deburring wheel will create heat.
Another option is a radius wheel with a sanding belt on it.
If you concentrate finger pressure at the very edge only with your finish stone, you'll remove all of the wear you're seeing and the problem will cease. no rolling the edge up or anything will be needed - just continue to sharpen using pressure at the edge from above.
Japanese chisels would be a pain without the ura because their hardness is well above anything silica based (the bulk of what's in a japanese natural stone, aside from 15-20% alumina), and on top of that, the hardness slows down the speed of the alumina a lot.
The key to getting something initially flat is using something fast enough to remove material so that you're not encouraged to bias pressure toward the edge in earlier steps. If edge refinement isn't perfect because of a few deeper scratches, they will eventually leave in subsequent resharpenings.
Messages In This Thread
Creating a mini-ura with buffing wheel?
Re: Creating a mini-ura with buffing wheel?
finger pressure...
Side sharpening
Re: Side sharpening
Re: Side sharpening
Ruler trick
in plane iron testing, I found two options..
Re: in plane iron testing, I found two options..
testing high angles..
side comment about planing in general..
I'll demonstrate thick sometime ..
Re: I'll demonstrate thick sometime ..
Patience ...
I re-read the articles on COE
High benches and low benches
Re: High benches and low benches
This isn't a snarky response, by the way
Others who do ..
Re: Others who do ..
Where I am going....
by the way...
I risk offending a lot of people...
on the last bit...
One other case for effort...
Something precise.
Re: Initially flat
Rotary tool?
Re: Rotary tool?
Some context
Re: Some context
Re: Some context
A failed attempt *PIC*
Re: A failed attempt
this is a lie nielsen iron?
Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
Re: Stanley iron
That pretty much covers it...
Success with applying extra pressure near the edge *PIC*
Directed pressure and progressive work
Re: Success with applying extra pressure near the
Wear bevel *PIC*
Visual difference at the back edge of..
Re: Visual difference at the back edge of..
Sorry, I should've been more precise...
Mini-ura on a new Veritas blade *PIC*
Re: Mini-ura on a new Veritas blade
