Hand Tools
If the UK guys are correct...
David Weaver
..and these tall mortise chisels with long primaries were used often in production work, the second edge retention test shown above (monstrously less effort to use a bevel of this profile vs. a flat bevel) may go far in explaining why such a tool would come from the maker with a fat unicorn bevel or a long bevel necessitating the user apply a fat bevel.
The roundover on them is nice both in rotation and also just because the height of the profile is so tall that it's nice not to have it catch on the edge of a mortise.
The debate about whether or not the pigstickers were used bevel down or straight into the mortise rages on (I use them bevel down - they'd have a lot more friction in the mortise cutting if the full bevel was ridden on them, especially on the early ones that had soft iron backing instead of hardened steel through and through).
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
eek...expensive..
judging scratches
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
for testing plane blade durability..
Tormek
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
if the tormek had a higher speed leather wheel...
David & Winston
Re: David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Scratches from various compounds *PIC*
these results will require some study
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
Thank you for experimenting
looking forward to...
Further Observations
great work
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
I remember reading this...
Factory ground *PIC*
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
Marples catalog...
Some other things to try
I am anxious to try your suggestion *NM*
Re: Some other things to try
Scratches from more compounds; buff vs stick *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
great experiments
Re: great experiments *PIC*
Other Compounds
Re: Other Compounds *PIC*
Well! good work
partly my fault for voluminous posts..
Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes—Steve Voigt link *LINK*
hardness of iron oxide
Re: hardness of iron oxide
Google monster says
Red stuff
File in useless knowledge
Re: Other Compounds - reinventing the wheel...
will do...
Correction
Calcined alumina *PIC*
sounds like gunpowder...
Profile pictures *PIC*
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
but, do I need to?
Outstanding work, Winston! *NM*
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Thoughts on the data
Re: Thoughts on the data
Scale of Image
Comparative Profile Pictures
I have never looked closely at...
Re: Comparative Profile Pictures
Separate on the IH sorby chisels..
