Hand Tools
Separate on the IH sorby chisels..
David Weaver
They're pretty well established to be factory ground exactly as I have them. The two that have been used haven't had the factory roundover removed or chased back yet -and those two have a primary bevel angle of exactly 25 degrees to a shinwa rule.
Not 25 1/4, 24. something, etc, they are absolutely dead on the line 25.
This is interesting as the speculation on the English site is that the oval bolstered mortice chisels were a production tool and not a cabinetmaker's tool. Production where mortises were deep (and if you have the opportunity to use one of these, they are superb to use on mortises deeper and longer than we would typically make in furniture).
The angle behind the round over is (by chance) almost identical to what I've come up with unicorning lighter chisels. They are undeniably faster to use in deep mortises than a single flat bevel they hold up well (unfortunately, it's rare that we would make much large enough to use them).
The chisels that I have are about 3 hundredths of an inch wider at the cutting end than they are at the tang, and the taper is even. The tops are about 3 hundredths narrower than the bottom of the cross section on the wider chisel and 2 on the narrower.
A bias in favor of the maker.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
eek...expensive..
judging scratches
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
for testing plane blade durability..
Tormek
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
if the tormek had a higher speed leather wheel...
David & Winston
Re: David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Scratches from various compounds *PIC*
these results will require some study
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
Thank you for experimenting
looking forward to...
Further Observations
great work
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
I remember reading this...
Factory ground *PIC*
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
Marples catalog...
Some other things to try
I am anxious to try your suggestion *NM*
Re: Some other things to try
Scratches from more compounds; buff vs stick *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
great experiments
Re: great experiments *PIC*
Other Compounds
Re: Other Compounds *PIC*
Well! good work
partly my fault for voluminous posts..
Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes—Steve Voigt link *LINK*
hardness of iron oxide
Re: hardness of iron oxide
Google monster says
Red stuff
File in useless knowledge
Re: Other Compounds - reinventing the wheel...
will do...
Correction
Calcined alumina *PIC*
sounds like gunpowder...
Profile pictures *PIC*
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
but, do I need to?
Outstanding work, Winston! *NM*
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Thoughts on the data
Re: Thoughts on the data
Scale of Image
Comparative Profile Pictures
I have never looked closely at...
Re: Comparative Profile Pictures
If the UK guys are correct...
