Hand Tools
Re: Factory ground 1816
David Weaver
Warren - it would seem to be short odds that my chisels (which didn't come from tooltique) have an identical grind on them, and tooltique's grinding wheel has so much influence that it would put the exact same profile on Bode's low use IH sorby chisels - from thousands of miles away.
I think you confuse "you haven't seen" in a marples catalog or a french book with "wasn't done" by some of the more highly regarded makers in England.
You're welcome to be confused, but you're incorrect in this case. The chisels show no sign of use, match low use or unused chisels in two other places, and you're grasping at marples catalog pages and digging in instead of saying "maybe that maker made them that way".
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
eek...expensive..
judging scratches
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
for testing plane blade durability..
Tormek
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
if the tormek had a higher speed leather wheel...
David & Winston
Re: David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Scratches from various compounds *PIC*
these results will require some study
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
Thank you for experimenting
looking forward to...
Further Observations
great work
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
I remember reading this...
Factory ground *PIC*
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
Marples catalog...
Some other things to try
I am anxious to try your suggestion *NM*
Re: Some other things to try
Scratches from more compounds; buff vs stick *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
great experiments
Re: great experiments *PIC*
Other Compounds
Re: Other Compounds *PIC*
Well! good work
partly my fault for voluminous posts..
Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes—Steve Voigt link *LINK*
hardness of iron oxide
Re: hardness of iron oxide
Google monster says
Red stuff
File in useless knowledge
Re: Other Compounds - reinventing the wheel...
will do...
Correction
Calcined alumina *PIC*
sounds like gunpowder...
Profile pictures *PIC*
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
but, do I need to?
Outstanding work, Winston! *NM*
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Thoughts on the data
Re: Thoughts on the data
Scale of Image
Comparative Profile Pictures
I have never looked closely at...
Re: Comparative Profile Pictures
Separate on the IH sorby chisels..
If the UK guys are correct...
