Hand Tools
will do...
David Weaver
i can share the part number of my favorite wheel, but I have probably over the years only tried 6 or so. No guarantee that a different type doesn't work better (more stitches to the edge, different material, etc).
Ryobi: A04BG06
there's differences in the number of plies, the number of stitches, where the stitches are, etc. No great reason to become an expert to save $10 (but I don't follow my own advice on that, i'll admit).
Those buff wheels show up unused from time to time, but I'm guessing based on the color of the packaging and the widespread availability of a different set of ryobi buffs that these are just old stock trickling out from oddball sellers (people who buy return lots, etc).
I see the sentiment is going toward finer here, but I'm inclined to stick with the yellow stuff because I'm used to it. The yellow stuff is 5 micron yellow jackson lea bar from mcmaster carr (calcined alumina). I think anything of reasonable quality will work well. I have no idea how many factors could affect my results (e.g., winston's bevels look a bit shorter and steeper - is that affected by the compound cutting power and the buff speed, both, etc?).
Sharpness is absurd even with yellow, and a complete result is almost guaranteed because the buffer doesn't just finish the edge that's there, it removes some of it and replaces the front side.
https://www.mcmaster.com/buffing-bars (listed as yellow in the top section under "cutting/coloring" category)
Will report back if experience with other bars is better, though. I think with a high speed buff and a wheel with a little bit of back bone, much of the compounds should be interchangeable.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
eek...expensive..
judging scratches
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
for testing plane blade durability..
Tormek
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
if the tormek had a higher speed leather wheel...
David & Winston
Re: David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Scratches from various compounds *PIC*
these results will require some study
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
Thank you for experimenting
looking forward to...
Further Observations
great work
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
I remember reading this...
Factory ground *PIC*
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
Marples catalog...
Some other things to try
I am anxious to try your suggestion *NM*
Re: Some other things to try
Scratches from more compounds; buff vs stick *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
great experiments
Re: great experiments *PIC*
Other Compounds
Re: Other Compounds *PIC*
Well! good work
partly my fault for voluminous posts..
Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes—Steve Voigt link *LINK*
hardness of iron oxide
Re: hardness of iron oxide
Google monster says
Red stuff
File in useless knowledge
Re: Other Compounds - reinventing the wheel...
will do...
Correction
Calcined alumina *PIC*
sounds like gunpowder...
Profile pictures *PIC*
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
but, do I need to?
Outstanding work, Winston! *NM*
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Thoughts on the data
Re: Thoughts on the data
Scale of Image
Comparative Profile Pictures
I have never looked closely at...
Re: Comparative Profile Pictures
Separate on the IH sorby chisels..
If the UK guys are correct...
