Hand Tools
Scratches from more compounds; buff vs stick *PIC*
Winston
I decided to look at some more buffing compounds, and see what size scratches they leave. Previously, I used some mystery compounds that came with a strop I ordered from Amazon and rubbed the sticks directly on the blade, because I didn't want to commit a buffing wheel to some unknown compound.
This time, I ordered buffing compounds from McMaster-Carr. (Thanks, Bill, for recommending them -- I'm very impressed that they delivered it in one day with no extra charges!) I got a yellow bar, which is 5 micron calcined alumina, and a green one, which is 1 micron chrome oxide, and I trust that they actually are what they're claim to be. My understanding is that David uses the yellow stuff.
First, I buffed the blade with the white rouge that came in the Ryobi kit, using the soft cotton wheel that was also in the kit.
Next, I used the green 1-micron stuff on a new buffing wheel:
Then I buffed the blade with the white rouge again to get it really smooth, and then I used the yellow 5-micron compound:
Although these compounds leave results that look quite different, they all left an extremely sharp blade. With all of them, I was able to shave hairs without the blade contacting my skin.
Even if they all leave a blade that's equivalently sharp in actual practice, I still like the idea of using the finest one. I just wish I knew where I could get some more of the white rouge -- the stick that I have is tiny and definitely won't last forever.
I also tried rubbing the bars directly on the blade -- I was curious to see if I could do that in the future to get a sense of what size scratches a compound would leave when used on a buffing wheel, without actually committing a buffing wheel to the compound.
Here's the white rouge:
Green 1-micron:
Yellow 5-micron:
So it looks like, for all of the compounds, using the stick directly on the blade leaves somewhat deeper scratches, compared to using them on a wheel. That makes sense.
One other interesting thing... Before doing all of the photos above, I sharpened the blade on a 1000-grit diamond plate and then buffed it with the white rouge. I ended up with a slightly wavy edge, which was even visible to the naked eye. I think I probably had raised a large burr, one big enough that the buffing wheel had trouble removing cleanly. This is what it looked like.
The blade was still extremely sharp, but I didn't want the waviness to show up in the subsequent photos, so I went back and honed it with a Shapton Pro 1000 before doing the tests above.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
eek...expensive..
judging scratches
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
for testing plane blade durability..
Tormek
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
if the tormek had a higher speed leather wheel...
David & Winston
Re: David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Scratches from various compounds *PIC*
these results will require some study
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
Thank you for experimenting
looking forward to...
Further Observations
great work
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
I remember reading this...
Factory ground *PIC*
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
Marples catalog...
Some other things to try
I am anxious to try your suggestion *NM*
Re: Some other things to try
Re: Scratches from more compounds; buff vs stick
wait till you try...
great experiments
Re: great experiments *PIC*
Other Compounds
Re: Other Compounds *PIC*
Well! good work
partly my fault for voluminous posts..
Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes—Steve Voigt link *LINK*
hardness of iron oxide
Re: hardness of iron oxide
Google monster says
Red stuff
File in useless knowledge
Re: Other Compounds - reinventing the wheel...
will do...
Correction
Calcined alumina *PIC*
sounds like gunpowder...
Profile pictures *PIC*
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
but, do I need to?
Outstanding work, Winston! *NM*
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Thoughts on the data
Re: Thoughts on the data
Scale of Image
Comparative Profile Pictures
I have never looked closely at...
Re: Comparative Profile Pictures
Separate on the IH sorby chisels..
If the UK guys are correct...
