Hand Tools
if the tormek had a higher speed leather wheel...
Tormek ()
David Weaver
..it probably would've done well. The trouble is that it doesn't have the speed to finish the job on the buffing side.
I always thought folks who touted the tormek as a finishing device (or as saying it's faster) were missing either nerve endings or some basic experience.
Interestingly, the pa-70, which smells, feels and finishes identically to autosol (and i'm pretty sure that's what it is - my microscope works as the expert witness on it) is quite nice on a strop if you want a pasted strop.
For whatever reason, the buffer is a softer background working at a higher speed and it doesn't settle into the tracks from prior abrasive.
Importantly, though, it's only a tiny bit of the edge, or there's no unicorn. Slow speed strops don't seem to excel at this. High speed aggressive strops, same. A medium stone and then the buffer used very specifically ends up being mama bear's stuff.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
eek...expensive..
judging scratches
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
for testing plane blade durability..
Tormek
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
David & Winston
Re: David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Scratches from various compounds *PIC*
these results will require some study
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
Thank you for experimenting
looking forward to...
Further Observations
great work
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
I remember reading this...
Factory ground *PIC*
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
Marples catalog...
Some other things to try
I am anxious to try your suggestion *NM*
Re: Some other things to try
Scratches from more compounds; buff vs stick *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
great experiments
Re: great experiments *PIC*
Other Compounds
Re: Other Compounds *PIC*
Well! good work
partly my fault for voluminous posts..
Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes—Steve Voigt link *LINK*
hardness of iron oxide
Re: hardness of iron oxide
Google monster says
Red stuff
File in useless knowledge
Re: Other Compounds - reinventing the wheel...
will do...
Correction
Calcined alumina *PIC*
sounds like gunpowder...
Profile pictures *PIC*
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
but, do I need to?
Outstanding work, Winston! *NM*
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Thoughts on the data
Re: Thoughts on the data
Scale of Image
Comparative Profile Pictures
I have never looked closely at...
Re: Comparative Profile Pictures
Separate on the IH sorby chisels..
If the UK guys are correct...
