Turning Archive
Do you have a picture of the tool or a link with the picture? Does it have a brand name? Did it come from a store or an individual?
When you say "round carbide cutting insert" is the insert a flat disk, a cupped disk? If so, what diameter? A larger diameter disk be very grabby. A smaller diameter disk can be more controllable.
A bowl gouge can cut with just a tiny bit of the edge at the tip and can be very controllable. The small cupped carbide disk such as on the Hunter Hercules can be used much like a bowl gouge once you know how.
These are typical bowl gouges:
This is a carbide scraper, intended for finishing, not hollowing bowls:
These can be grabby if used improperly and even otherwise result in a horrible surface finish compared to a sharp gouge. Another issue is trying to use the tool with too much over hang off the tool rest. A big issue is presentation of the tool at the right position and angle - get it wrong, bam.
I only use a scraper on the inside of a bowl after hollowing and only if I have trouble removing tool marks. Even then, it's not a carbide disk but a HSS tool ground with a negative rake.
I agree with the others. 30 minutes with an experienced woodturner could identify the problem and provide a solution. Perhaps attend a club meeting in your area and ask there and meet some turners who would be glad to help.
Or take a class with a good instructor.
Messages In This Thread
- bowl turning
- buying tools without handles *PIC*
- My head IS spinning......
- Re: bowl turning
- Two rules for the scraper
- Re: bowl turning
- Re: bowl turning
- Wood orientation? *LINK*
- Re: bowl turning
