Turning Archive
Re: Vari-grind
Re: Vari-grind ()
>>>...and your opinion of the Vari-grind 2
Butting in with my 2 cents - I've had the Vari-grind for a bunch of years then bought the Vari-grind 2 when it came out. While the design seemed like a good idea, I dislike the Vari-grind 2 mostly because it forces the cut in the center of the wheel. I prefer to spread out the wear over the entire width of the wheel instead of just the center. With a stone wheel it would just mean dressing more often and earlier wheel diameter reduction. With the CBN I don't know.
Some people say they like it since it prevents accidentally letting the gouge slip off the side of the grinding wheel. I don't quite understand since I have never had this happen with the original Vari-grind.
My Vari-grind 2 hangs on the wall. I only keep it so visitors can try it to see if they like it.
