Turning Archive
Re: Wolverine/Vari grind helpResponse To:
Re: Wolverine/Vari grind help () jake niedling
When you start moving the vari-grind leg, you will need to keep slighly adjusting the vee block position to maintain the nose angle. It does take some playing, but you will get it to match. It is always a good thing to match how much of the tool is sticking out past the vari-grind jig. I have seen 2" used alot, but have seen some people use 1.75" as well. You could have Mark just trace the outline of the tool and the vari-grind and send it to you.
Messages In This Thread
- Wolverine/Vari grind help
- Re: Wolverine/Vari grind help
- Vari-grind basket height vs distance past jig?
- Re: Vari-grind basket height vs distance past jig?
- https://youtu.be/5sTx5SbGDJI
- good instructions...
- Go to this page on Thompson Lathe Tools *LINK*
