Turning Archive
Re: Wolverine/Vari grind help
Wolverine/Vari grind help ()
George Balock
Robert,
Once you have the setting on the v-block set to match the nose angle, you move the arm on the Vari Grind to match the angle on the wings. It may take a little fiddling with it to get it right. As a little guide to see where you are grinding, you can take a marker and mark the wings on your gouge to see where the wheel is touching. Hope this helps.
