Re: crest complete (And more dursol)
Sgian Dubh
" Richard mentioned in a post below that it takes longer to remove wear from the back of an iron than I suggested."
David, are you referring to something I might have said in a post somewhere? I can't recall suggesting it takes particularly long to keep the flat face of a chisel or plane iron flat. I am well aware of the fact that using a standard bevel down bench plane, such as a Stanley, or a Clifton through the range of, say, no 4 to no 7 or 8 results in wear to the flat face through general dulling and as the shaving slides up the flat face until it meets the cap iron. A chisel's flat face can also get a bit rounded, convex, but the precise causative mechanism(s) is/are probably a bit harder to pin down than is the case with plane irons, apart from the obvious dulling of the cutting edge caused by use.
I have said to you privately that I usually, probably 90 percent of the time, therefore not always, sharpen a dull tool (bench plane iron or bench chisel) by working the flat face of the tool first just to make sure that flat face is flat. It usually only takes a few seconds, maybe eight to fifteen I guess - I've never timed it. I'm not sure that I've ever specifically described that initial sharpening stage I use at this forum, but I might have done and just don't recall it.
Following that bit of work on the flat face I work the honing angle, then it's back to the flat face with, ideally, the end of the tool hanging over the edge of the stone and the initial movement a backward drag to turn the burr (wire edge) away from the tool's cutting edge, a bit of swishing about follows, then something like three to six alternating single backward strokes on the honing angle and the flat face. After that, up 'til now all I've done with the tool is a bit of flipping back and forth on the palm of my hand, and back to work. However, as I've mentioned elsewhere, your 'unicorning' thing is intriguing and potentially useful; I just haven't had a real opportunity to play with the technique much, except to say I've already found it does seem to work nicely on gouges. Slainte.
Messages In This Thread
Sharpening Stone Ominbus - here we go
White Cretan - Novaculite *PIC*
stone pics... *PIC*
Black Sedimentary Stone *PIC*
pic of the stone *PIC*
Norton Queer Creek *PIC*
Pic of the stone *PIC*
Re: Pic of the stone
Re: Pic of the stone *PIC*
Purple Welsh Slate *PIC*
edge picture with a razor *PIC*
Very dense....
Re: Purple Welsh Slate *PIC*
Owyhee Jasper *PIC*
picture of the stone *PIC*
Chinese Agate *PIC*
crest complete (And more dursol) *PIC*
separate, since you got caught in the net...
Re: separate, since you got caught in the net...
Wrong R
Greasy/Coated India Stone *PIC*
Re: Greasy/Coated India Stone *PIC*
Gray China (Guangxhi?) natural waterstone *PIC*
Linde A - Paraffin Buffing Bar *PIC*
Try bee wax
Fine buffing compound
practically...
one other side benefit
Also with iron oxide bar
Picture of the "stone" *PIC*
The real Llyn Idwall *PIC*
Picture of the stone *PIC*
Re: Picture of the stone
two llyn idwalls
Re: two llyn idwalls
Black Hone Slate *PIC*
Smiths Hard Arkansas *PIC*
pictures of the stone *PIC*
Re: Smiths Hard Arkansas
Japanese "Barber Oilstone" *PIC*
Pictures of the stone *PIC*
Slurried Trans Ark.. *PIC*
Am I understanding......
Re: Am I understanding......
This is sort of a loaded situation...
Re: This is sort of a loaded situation...
The other real issue with japanese finishers..
Clarifying hollow grind
dan's and washita.
Soft India?
soft vs. hard
Re: Soft India?
Now I am more confused
Re: I will make an exception…
Separately - a very good point made
Not defending wiley...
Re: Now I am more confused
That explanation makes sense *NM*
Extra Fine India Stone *PIC*
Sigma Power 13k *PIC*
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
The rules of accommodation
Re: The rules of accommodation
Jackson Lea 5 micron "yellowcake" on softwood *PIC*
Is poplar soft enough
Re: Is poplar soft enough
picture of the wax bar *PIC*
Llyn Idwall *PIC*
Re: Llyn Idwall
Re: Llyn Idwall
Charnley Forest
releasing particles
Turkish Oilstone *PIC*
Dursol (Autosol) Metal Polish *PIC*
Tying up loose polishes - Autosol *PIC*
Re: Tying up loose polishes - Autosol
pic of the dursol *PIC*
(this one is good enough for everyone)
Re: (this one is good enough for everyone)
LV Green / Formax Microfine *PIC*
picture of the compound *PIC*
attractive old wives tales
Relevance? Question?
Re: Relevance? Question?
Clear summary thanks
Another White Alundum Japanese Stone *PIC*
Re: Another White Alundum Japanese Stone *PIC*
Very expensive (to me) japanese natural *PIC*
Re: Very expensive (to me) japanese natural
Dan's black Hard Ark *PIC*
Coticules - Fine and Coarse *PIC*
pic of the stones *PIC*
garnet
not sure
Unknown Japanese White Alundum *PIC*
the stone.. *PIC*
question
Looking at this picture..
I do both
Hand American 0.5 micron Green Chrome Ox *PIC*
pic of the oxide *PIC*
The purpose of the omnibus...
Not unicorn related, more clear
What else the creator of the weaver bevel post? *NM*
question for David
Re: question for David
Thanks David *NM*
Supremely Fine Japanese Natural Razor Stone *PIC*
Re: Thank you, David
very few will care about mines or stamps...
Practical question
Re: Practical question + another regarding scale..
Scale overlay
Re: Scale overlay
sorry, addressed differently
request
Brief comments...
Fine White Okudo Suita *PIC*
Shapton Cream *PIC*
Fine washita *PIC*
Kitayama waterstone *PIC*
Re: Kitayama waterstone *PIC*
