Re: Relevance? Question?
Relevance? Question? ()
David Weaver
Yes, it takes a while to wear the defects out and the person doing the planing is cheated out of the sweetest part of the planing.
The defects actually get a little worse for a while as they break off due to lack of lateral support and then wear makes the edge more uniform.
This wasn't covered in our plane iron tests because all of the edges were confirmed uniform end to end before planing.
Yes on the buffer as long as there's no clearance issue. I think it's not a bad idea to get a hand scope (for anyone who does a *lot* of planing, folks who do small amounts/fitting or work on joints with a bunch of glue lines and scrape and sand probably won't care as much). It takes no more time to make an edge that's uniform (without buffer) than it does to make one that is uniform.
When warren talks about sharpening far more frequently than absolutely needed and avoiding damage, I believe it's to aid this.
My discussion of separating geometry from edge honing is generally to make it so that you can do the same thing even when an edge is completely worn or has minor damage.
On chisels, the buffer does this well. On bevel up, well. With some touch, on bevel down plane irons, it does it well, but if it took me about 10 irons to really figure out the touch, someone who is less enthusiastic may not have an opportunity to make the feel a feel (as in, they may not be able to do it consistently without running the clearance out). That's what I'm seeing so far in comments from various forums - chisel success is almost immediate (which means folks who use a 25 degree BU iron, if they take the time to stone all of the damage off of the flat side of the iron, will have a super BU plane experience if they just buff a 25 degree bevel on the bevel side of their plane. that should be immediate, and if it's not, it's probably a problem on the back side of the blade.
But I can see BD planes vexing people off and on where doing the same geometry (20/23 and then adding a tiny microbevel at 33 or so with a honing guide on fine media would be more successful for most on bevel down planes).
Messages In This Thread
Sharpening Stone Ominbus - here we go
White Cretan - Novaculite *PIC*
stone pics... *PIC*
Black Sedimentary Stone *PIC*
pic of the stone *PIC*
Norton Queer Creek *PIC*
Pic of the stone *PIC*
Re: Pic of the stone
Re: Pic of the stone *PIC*
Purple Welsh Slate *PIC*
edge picture with a razor *PIC*
Very dense....
Re: Purple Welsh Slate *PIC*
Owyhee Jasper *PIC*
picture of the stone *PIC*
Chinese Agate *PIC*
crest complete (And more dursol) *PIC*
Re: crest complete (And more dursol)
separate, since you got caught in the net...
Re: separate, since you got caught in the net...
Wrong R
Greasy/Coated India Stone *PIC*
Re: Greasy/Coated India Stone *PIC*
Gray China (Guangxhi?) natural waterstone *PIC*
Linde A - Paraffin Buffing Bar *PIC*
Try bee wax
Fine buffing compound
practically...
one other side benefit
Also with iron oxide bar
Picture of the "stone" *PIC*
The real Llyn Idwall *PIC*
Picture of the stone *PIC*
Re: Picture of the stone
two llyn idwalls
Re: two llyn idwalls
Black Hone Slate *PIC*
Smiths Hard Arkansas *PIC*
pictures of the stone *PIC*
Re: Smiths Hard Arkansas
Japanese "Barber Oilstone" *PIC*
Pictures of the stone *PIC*
Slurried Trans Ark.. *PIC*
Am I understanding......
Re: Am I understanding......
This is sort of a loaded situation...
Re: This is sort of a loaded situation...
The other real issue with japanese finishers..
Clarifying hollow grind
dan's and washita.
Soft India?
soft vs. hard
Re: Soft India?
Now I am more confused
Re: I will make an exception…
Separately - a very good point made
Not defending wiley...
Re: Now I am more confused
That explanation makes sense *NM*
Extra Fine India Stone *PIC*
Sigma Power 13k *PIC*
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
The rules of accommodation
Re: The rules of accommodation
Jackson Lea 5 micron "yellowcake" on softwood *PIC*
Is poplar soft enough
Re: Is poplar soft enough
picture of the wax bar *PIC*
Llyn Idwall *PIC*
Re: Llyn Idwall
Re: Llyn Idwall
Charnley Forest
releasing particles
Turkish Oilstone *PIC*
Dursol (Autosol) Metal Polish *PIC*
Tying up loose polishes - Autosol *PIC*
Re: Tying up loose polishes - Autosol
pic of the dursol *PIC*
(this one is good enough for everyone)
Re: (this one is good enough for everyone)
LV Green / Formax Microfine *PIC*
picture of the compound *PIC*
attractive old wives tales
Clear summary thanks
Another White Alundum Japanese Stone *PIC*
Re: Another White Alundum Japanese Stone *PIC*
Very expensive (to me) japanese natural *PIC*
Re: Very expensive (to me) japanese natural
Dan's black Hard Ark *PIC*
Coticules - Fine and Coarse *PIC*
pic of the stones *PIC*
garnet
not sure
Unknown Japanese White Alundum *PIC*
the stone.. *PIC*
question
Looking at this picture..
I do both
Hand American 0.5 micron Green Chrome Ox *PIC*
pic of the oxide *PIC*
The purpose of the omnibus...
Not unicorn related, more clear
What else the creator of the weaver bevel post? *NM*
question for David
Re: question for David
Thanks David *NM*
Supremely Fine Japanese Natural Razor Stone *PIC*
Re: Thank you, David
very few will care about mines or stamps...
Practical question
Re: Practical question + another regarding scale..
Scale overlay
Re: Scale overlay
sorry, addressed differently
request
Brief comments...
Fine White Okudo Suita *PIC*
Shapton Cream *PIC*
Fine washita *PIC*
Kitayama waterstone *PIC*
Re: Kitayama waterstone *PIC*
