I do both
question ()
David Weaver
but most of the time finish with diagonal strokes (at least partially) into the edge to weaken a wire edge, so straight scratches remain.
whatever a stone seems to like to work quickly, I do when getting the first 5 or 10 seconds of work done. When you're working with any stone that doesn't allow good cutting action however you move a tool around (diamond on cast doesn't care which way you move it, for example, it just cuts any way). On stones sometimes, when there is an abrasive slurry, if one just pushes a blade up and down the stone, some of them will cause skidding (shaptons do) and you get better cutting action if focusing small strokes in a spot (to keep the metal in contact with the stone, and not skidding on a loaded area) and gradually move that spot down the stone, it works much faster and the stone isn't loaded.
Or to be plainer, you do whatever you need to to keep the steel in contact with abrasive and not floating on an area that's loading/clogged or where a sloppy swarf is preventing good abrasion.
I like the circles, but haven't done any testing to see if they have any advantage. I also like the last few strokes to terminate in the edge at not be side to side so that if one of them is deep, the area of damage is just where the stroke terminates, and not a section of edge that comes off many times wider than the groove. Plus, the "tooth" that way feels subjectively a little sharper.
Circles are often good with heavy pressure in a small area on a stone that exhibits loading or suspending behavior because the iron doesn't escape an area where it's in good contact.
This is all personal preference, though - led by laziness (whatever seems to work fastest with the least effort).
Separate from these stones, there is a large improvement in flattening the backs of tools on sandpaper if the back flattening is finished with circular strokes - the number of dominant deep grooves from the sandpaper seems to be far less. I'll try to get a picture of that - it allows someone to, for example, go from worn 80 grit paper to a middle stone right away without steps between, and takes about 10 seconds to remove the dominant deep in line grooves that someone may get preparing an iron that's far out of flat.
As to the circles vs. lines, etc, one of the hallmarks of a beginner's stone is that it tolerates just about anything someone can do regardless of the way they move a tool. A fine india stone is kind of like this - you can take long strokes, do circles, whatever you want, and it cuts the same. A step or two finer than fine india (which is harder to find) does the same thing. Diamond on cast is like this on the backs of tools - move the tool around, the stone works).
Stones of nuance (Washita, oilstones, japanese natural stones), you can manipulate those things to make a stone work finer or faster, but I doubt most people have any interest in that - it's really only critical for razor sharpening.
Messages In This Thread
Sharpening Stone Ominbus - here we go
White Cretan - Novaculite *PIC*
stone pics... *PIC*
Black Sedimentary Stone *PIC*
pic of the stone *PIC*
Norton Queer Creek *PIC*
Pic of the stone *PIC*
Re: Pic of the stone
Re: Pic of the stone *PIC*
Purple Welsh Slate *PIC*
edge picture with a razor *PIC*
Very dense....
Re: Purple Welsh Slate *PIC*
Owyhee Jasper *PIC*
picture of the stone *PIC*
Chinese Agate *PIC*
crest complete (And more dursol) *PIC*
Re: crest complete (And more dursol)
separate, since you got caught in the net...
Re: separate, since you got caught in the net...
Wrong R
Greasy/Coated India Stone *PIC*
Re: Greasy/Coated India Stone *PIC*
Gray China (Guangxhi?) natural waterstone *PIC*
Linde A - Paraffin Buffing Bar *PIC*
Try bee wax
Fine buffing compound
practically...
one other side benefit
Also with iron oxide bar
Picture of the "stone" *PIC*
The real Llyn Idwall *PIC*
Picture of the stone *PIC*
Re: Picture of the stone
two llyn idwalls
Re: two llyn idwalls
Black Hone Slate *PIC*
Smiths Hard Arkansas *PIC*
pictures of the stone *PIC*
Re: Smiths Hard Arkansas
Japanese "Barber Oilstone" *PIC*
Pictures of the stone *PIC*
Slurried Trans Ark.. *PIC*
Am I understanding......
Re: Am I understanding......
This is sort of a loaded situation...
Re: This is sort of a loaded situation...
The other real issue with japanese finishers..
Clarifying hollow grind
dan's and washita.
Soft India?
soft vs. hard
Re: Soft India?
Now I am more confused
Re: I will make an exception…
Separately - a very good point made
Not defending wiley...
Re: Now I am more confused
That explanation makes sense *NM*
Extra Fine India Stone *PIC*
Sigma Power 13k *PIC*
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
Re: Sigma Power 13k
The rules of accommodation
Re: The rules of accommodation
Jackson Lea 5 micron "yellowcake" on softwood *PIC*
Is poplar soft enough
Re: Is poplar soft enough
picture of the wax bar *PIC*
Llyn Idwall *PIC*
Re: Llyn Idwall
Re: Llyn Idwall
Charnley Forest
releasing particles
Turkish Oilstone *PIC*
Dursol (Autosol) Metal Polish *PIC*
Tying up loose polishes - Autosol *PIC*
Re: Tying up loose polishes - Autosol
pic of the dursol *PIC*
(this one is good enough for everyone)
Re: (this one is good enough for everyone)
LV Green / Formax Microfine *PIC*
picture of the compound *PIC*
attractive old wives tales
Relevance? Question?
Re: Relevance? Question?
Clear summary thanks
Another White Alundum Japanese Stone *PIC*
Re: Another White Alundum Japanese Stone *PIC*
Very expensive (to me) japanese natural *PIC*
Re: Very expensive (to me) japanese natural
Dan's black Hard Ark *PIC*
Coticules - Fine and Coarse *PIC*
pic of the stones *PIC*
garnet
not sure
Unknown Japanese White Alundum *PIC*
the stone.. *PIC*
question
Looking at this picture..
I do both
Hand American 0.5 micron Green Chrome Ox *PIC*
pic of the oxide *PIC*
The purpose of the omnibus...
Not unicorn related, more clear
What else the creator of the weaver bevel post? *NM*
question for David
Re: question for David
Thanks David *NM*
Supremely Fine Japanese Natural Razor Stone *PIC*
Re: Thank you, David
very few will care about mines or stamps...
Practical question
Re: Practical question + another regarding scale..
Scale overlay
Re: Scale overlay
sorry, addressed differently
request
Brief comments...
Fine White Okudo Suita *PIC*
Shapton Cream *PIC*
Fine washita *PIC*
Kitayama waterstone *PIC*
Re: Kitayama waterstone *PIC*
