Separate on the IH sorby chisels..
David Weaver
They're pretty well established to be factory ground exactly as I have them. The two that have been used haven't had the factory roundover removed or chased back yet -and those two have a primary bevel angle of exactly 25 degrees to a shinwa rule.
Not 25 1/4, 24. something, etc, they are absolutely dead on the line 25.
This is interesting as the speculation on the English site is that the oval bolstered mortice chisels were a production tool and not a cabinetmaker's tool. Production where mortises were deep (and if you have the opportunity to use one of these, they are superb to use on mortises deeper and longer than we would typically make in furniture).
The angle behind the round over is (by chance) almost identical to what I've come up with unicorning lighter chisels. They are undeniably faster to use in deep mortises than a single flat bevel they hold up well (unfortunately, it's rare that we would make much large enough to use them).
The chisels that I have are about 3 hundredths of an inch wider at the cutting end than they are at the tang, and the taper is even. The tops are about 3 hundredths narrower than the bottom of the cross section on the wider chisel and 2 on the narrower.
A bias in favor of the maker.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
