Re: Factory ground
Factory ground *PIC* ()
David Weaver
Actually, you saw the factory grind in my picture.
I have a full set of these chisels. The grind marks are the same top to bottom, end to end and the same on the small bevel as they are on the side of the chisel.
I have two in the set that I've used - those obviously don't look the same.
I never looked closely at them before - all may have been unused, and were perhaps worthy of leaving unused if I'd thought about it.
The maker is IH sorby, as good as any maker that's ever existed (better than marples).
(edit, further look - same owner mark, same handles - the whole set is IH sorby, but with two different marks. One is the typical letters only with serifs and no border, and the other is the stamp shown below).
I believe these are probably middle 1800s. This mark started around 1825. I am not a collector, I bought this set of chisels because they were relatively cheap (about $25 each). It looks like later oval bolstered chisels came with a flat grind on the bevel, but that may have been a cost cut by then.
To reiterate what's said above, the bevel is ground, it doesn't look like it was ever finish honed, as the grind marks on the small bevel are the same as the rest of the chisel. No evidence of having ever been honed on the back of the chisel, either - the factory grind goes all the way to the edge, except on the two that I've used, the factory marks are long gone (further up than I've honed them, also).
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
