Re: Angle near the edge
Re: Angle near the edge ()
Winston
> You can get the effective cutting angle, before and/or after, by running the chisel bevel down across your benchtop, and check the angle where it first begins to dig in. Do this beside a vertical surface like a block of 2x4, mark the angle where the chisel begins to bite, and check that angle with your own protractor.
I gave it a try. On a very smooth planed piece of white pine, I got anywhere between about 35 and 42 degrees. It's hard to get a consistent reading. The angle where it first digs in is sensitive to amount of downward pressure. If the chisel gets rotated (along the long axis) a bit in either direction, the corners dig in, and then if I try to stabilize it by putting a little bit of pressure near the tip (as if sharpening freehand), that makes it want to dig in at a lower angle than it would otherwise. As I raise the angle, there's also a range of angles where it stutters but doesn't quite catch. So... in short, in order to get a consistent value, I think the variables would have to be controlled much better than I'm able to do.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
