Scratches from various compounds *PIC*
Winston
With the talk about stropping and compounds, I decided to see what the scratches look like from different compounds.
This time I started off with an edge from a Sigma Power Ceramic 6000. I again didn't do anything to the back, so if you look closely, you can see a bit of burr hanging on (it's quite a bit darker).
I wanted to start with a smooth surface before trying out the other compounds, so I first buffed it with the white rouge.
I have a leather strop with (supposedly) 1 micron diamond paste on it, so I stropped it maybe five times at a higher angle. This is unbranded diamond paste I bought on eBay about 10 years ago. I remember that it was very inexpensive.
A little background before the next pictures. I recently bought a strop that came with two compounds: a coarser white aluminum oxide which is supposedly 1 micron, and a green aluminum oxide that's supposedly 0.5 micron. I haven't put either compound on the strop yet.
First, I buffed the blade with the white rouge to get a smooth surface. Then, I dragged the blade backward on the stick of green aluminum oxide compound a few times.
Finally, the white aluminum oxide. This is the same stuff I had used before with a buffing wheel, but for consistency, I just used the stick directly this time. I buffed the blade smooth again, and then dragged the blade backward on the white stick a few times.
I should say again that the blade seemed extremely sharp after all of these steps. It's possible that for the unicorn grind, the scratch size doesn't matter much for durability, but that it's the rounded edge profile that really matters.
So far, the white rouge has left by far the smoothest surface. Apparently, the abrasives aren't as hard as others. Here's one description I found: "White rouge: An extremely dry grade of compound made with ultra-fine, soft abrasive powders. Produces a clear, brilliant, mirror-like finish on chromium, stainless, carbon steel, brass and aluminum."
So maybe the reason it's leaving such a smooth surface is because it's softer, compared to abrasives like diamond and aluminum oxide. On something that's hand "powered" like a strop, you might want a very hard abrasive so that it works quickly, but on a powered buffing wheel, a softer, slower abrasive is still plenty fast for working on a tiny region like this, and will leave a smoother surface. (The drill I used for this can do 1600 rpm, and with a 4" wheel, that's a surface speed of 28 feet per second. A 6" bench buffer has a surface speed of 94 feet per second.)
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
