David & Winston
David and Winston....it may become like the Watson and Crick of Woodworking .
Will you all compare and contrast exactly what you are using on the buffer. I am unfamiliar with buffing compounds. Are they the same, do they seem to be working the same if they are not the same and how do I know if I have bought the equivalent?
When you become guru status it is critical that the David and Watson groopies do exactly as you do. :)
I discovered I have a buffing wheel I bought decades ago. Still in the box. And it came with some sticks of stuff. How do I know if the buffing wheel will be equivalent, what to look for?
Do you have introductory kits available on Ebay :b
Note I am not in the shop. Annoyed. Cut first two slips to width. Fit. Cut the next 8 the same only to discover these later pre-made a while back sticks of slip stock is enough different that the result is not wide enough. Start over.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
