eek...expensive..
Suzuki Tool 4000 ()
David Weaver
...I bought a gaggle of synthetic stones, but left playing with them too early to see these (presumably private label vitrified stone made by someone like bester).
Interesting review - what I take from it based on experience is that it's more coarse than a shapton 5000. The chosera is an oddball - it's a fine gritted stepping stone for knife sharpening. IIRC, about 3 microns and soft.
Same for the shapton 5k - something like 3 micron.
There's not much free lunch in synthetic sharpening stones, but I saw many promoted by gurus (not commenting on the suzuki stone) promising one. If it's faster and finer, it'll be softer. If it's faster and same hardness, it'll be coarser.
At some point, one of the knife suppliers made a dizzying array of what I'd call $50 stones but for about double that because they offered three hardnesses at each numerical rating.
Probably a direct comparison to the suzuki 4000 would be the chosera 3k, which is still even a fine stone (4 micron).
I've cast off most of them, though, and use an oil bath (crystolon and india stone) for coarse work, even on japanese tools. Those two don't stay that flat, but do fast prep (can be blindingly fast with the crystolons if not careful). I find that the very hard japanese tools don't mind that regimen unless they're overhard (the edge may crumble, but that's a tool problem, not something to coddle as the tool will punish a user each time it chips - interestingly, the unicorn bevel that we're talking about here is protected for overhard tools).
Anyway, I've seen the same thing with the scope - what looks less coarse and more matte can look similar under the scope. When stones get close together in fineness, it can be very hard to see a difference except to look at the very edge of the tool.
Messages In This Thread
Sharpening and buffing progression pictures *PIC*
Separate on the IH sorby chisels..
If the UK guys are correct...
Comparative Profile Pictures
Re: Comparative Profile Pictures
I have never looked closely at...
Profile pictures *PIC*
Thoughts on the data
Scale of Image
Re: Thoughts on the data
Angle near the edge *PIC*
Re: Angle near the edge
This is a difficult thing to do precisely
Capturing the Unicorn Profile
Re: Capturing the Unicorn Profile
Outstanding work, Winston! *NM*
but, do I need to?
Calcined alumina *PIC*
sounds like gunpowder...
Scratches from various compounds *PIC*
Scratches from more compounds; buff vs stick *PIC*
Other Compounds
Re: Other Compounds *PIC*
Correction
Re: Other Compounds - reinventing the wheel...
will do...
Well! good work
Red stuff
File in useless knowledge
partly my fault for voluminous posts..
hardness of iron oxide
Google monster says
Re: hardness of iron oxide
Wooden planes
Re: Wooden planes—Steve Voigt link *LINK*
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Re: Wooden planes
Thanks, Jon!!
Re: Wooden planes
great experiments
Re: great experiments *PIC*
Re: Scratches from more compounds; buff vs stick
wait till you try...
The white stuff is...
Re: The white stuff is...
various compounds - difficult to judge
Re: various compounds - difficult to judge
looking forward to...
Further Observations
Some other things to try
Re: Some other things to try
I am anxious to try your suggestion *NM*
Interesting..
Re: Interesting..
not sure I agree
Re: not sure I agree
Factory ground *PIC*
Marples catalog...
Re: Factory ground
Re: Factory ground 1816 *PIC*
blogger grind
Re: blogger grind *PIC*
you're still failing...
after you do your survey, you'll find
I remember reading this...
great work
Thank you for experimenting
these results will require some study
David & Winston
Buffing wheel vs hard felt
Re: Buffing wheel vs hard felt
Re: David & Winston
Thinking about establishing the Unicorn profile
Amen, Reverend
Re: Amen, Reverend
Tormek
if the tormek had a higher speed leather wheel...
Clarification, please
Re: Clarification, please
Preparing a beading blade
Re: Preparing a beading blade
for testing plane blade durability..
Re: Sharpening and buffing progression pictures
Suzuki Tool 4000
judging scratches
eek...expensive..
