konrad's planes...
Note on a modern infill ()
David Weaver
..are made closer to the vintage patterns, of course (and they look wonderful). I'd guess his plane (with the thicker iron and slightly more substantial lever cap, etc) is probably 6 ounces heavier than a typical norris A5 (I had two of those, both were beech - there actually fairly light - if more than 4 pounds, I"d have been surprised, but they weren't good planes in later trim in beech, either, and required a lot of work just to be tolerable. Tolerable was all I could get out of them. The adjuster was coarse and tough to use, and adding tension to the lever cap increased cutting depth, so the lever cap would become a secondary adjuster of sorts and allow several thousandths of adjustment in shaving thickness.
I copied (buying the lever cap and iron from Ron) Ron Brese's pattern for a "sort of" norris #13 single iron. Same metal thickness that Ron uses and bois de rose (boy would I like to have that blank of wood back - didn't know what it was) infill for a 2" plane and it came out around 5 1/2 pounds. It's a very pleasant plane to use if you use it for what it's good at, but not very productive for more than finish smoothing.
It'd be great to see a huge spectrum of weights, but it's hard to find good information. The first time I was really alarmed about the weight of a plane, there was a small spiers dovetail smoother on ebay, and the seller said that it was 2 pounds 15 ounces. I passed on buying it as I feared it wouldn't be heavy enough to work well (open handled and dainty). On the other end of the spectrum was the loopy...can't remember the weight, but I think that plane was a ruse (at least at first).
CS lists darell hutchinson and holtey a13s at 5lbs 15 oz and 6 lbs 2 oz, respectively. Karl's 98 at a little over 4 pounds.
at 5 1/2 pounds, my #13ish copy does feel heavy at 2" of width and it would be awkward trimming small things.
Messages In This Thread
Light vs Heavy planes
Re: Light vs Heavy planes
I like tools from Brooklyn
Re: I like tools from Brooklyn *NM*
Infills in the UK
I'm glad you commented.
Weight Comparison
more infill weights
Re: more infill weights
initial fitting...
one more follow-up comment.
Re: one more follow-up comment.
rosewood
Re: rosewood
now there is a pearl of wisdom
Re: I'm glad you commented.
what I've found...
Re: what I've found...
Re: Calling BS
Re: Calling BS
Re: Can't argue
Re: Calling BS
by the early 19th century
Re: by the early 19th century
It's not offered as ball court...
Re: It's not offered as ball court...
I'm guessing on parts here...
I miss Todd Hughes' contributions too *NM*
Re: Calling BS
Re: Calling BS
I think we're agreeing...
Re: I think we're agreeing...
Re: Me too
Wood isn't indefinitely stable, either
Re: Facts, not assertions
I haven't seen it....
Re: I haven't seen it....
Truing Kanna
expanding on what jim said
Coupla thoughts
different methods of lapping and the bump
interesting that...
konrad's planes...
new vs. old planes...
Turnover, newbies and FAQ
comment on teaching
If you get my drift...
finding out who to listen to...
Re: finding out who to listen to...
I agree...
Re: Same
Old history
Misprint?
Re: Misprint?
cultural thing...
Shops using mostly hand tools..
Re: Shops using mostly hand tools..
Don felder's guitar...
Not a positive contribution to the discussion
Inertia and figured wood
Re: Jim, what is Osae-gani? *NM*
Osae-gani
Re: Osae-gani
Note on fitting
biases for the maker...
Re:wedge fitting
Re:wedge fitting
funny...
Re: funny...
At some point..
The experiment and conclusion are both confusing
Re: Heavy and light
another factor
If you're trimming furniture...
The best case for heavy planes...
Re: reframing the issue
Friction, and more
not the direction I went *PIC*
5 1/4
