Note on fitting
Re: Osae-gani ()
Wiley Horne
Hi David,
To add to your point,
“ and the abutments have to be precise enough since there's no wedge - precise enough to keep the iron tight but not prevent it from getting it to the end of the plane.”
Western and Japanese woodies share this problem of precise fitting of the iron within the abutments. The Japanese plane has evolved to solve this problem by having the iron slightly sprung in the abutments. That’s how some practitioners are able to use the plane with no chipbreaker. The iron comes from the smith with a slight curvature (1-3 thousandths), based on measurements I made of a half dozen kanna some years ago.
Sometimes you see the western woodie with the wedge slightly sprung—scraped just a tiny bit hollow, so as to ensure a tight fit top and bottom of the iron. To be sure, we have also seen western woodies where the wedge was not sprung, just perfectly fitted its whole length. But overall I find it an interesting comparison of two ways to solve the same problem.
Not suggesting the Japanese iron is smithed with this curvature to aid fitting—no, surely it is a natural product of the welding and heat-treating process. But over time, the dai makers (who were often the users) figured out how to use this blade curvature to advantage.
Wiley
Messages In This Thread
Light vs Heavy planes
Re: Light vs Heavy planes
I like tools from Brooklyn
Re: I like tools from Brooklyn *NM*
Infills in the UK
I'm glad you commented.
Weight Comparison
more infill weights
Re: more infill weights
initial fitting...
one more follow-up comment.
Re: one more follow-up comment.
rosewood
Re: rosewood
now there is a pearl of wisdom
Re: I'm glad you commented.
what I've found...
Re: what I've found...
Re: Calling BS
Re: Calling BS
Re: Can't argue
Re: Calling BS
by the early 19th century
Re: by the early 19th century
It's not offered as ball court...
Re: It's not offered as ball court...
I'm guessing on parts here...
I miss Todd Hughes' contributions too *NM*
Re: Calling BS
Re: Calling BS
I think we're agreeing...
Re: I think we're agreeing...
Re: Me too
Wood isn't indefinitely stable, either
Re: Facts, not assertions
I haven't seen it....
Re: I haven't seen it....
Truing Kanna
expanding on what jim said
Coupla thoughts
different methods of lapping and the bump
interesting that...
Note on a modern infill
konrad's planes...
new vs. old planes...
Turnover, newbies and FAQ
comment on teaching
If you get my drift...
finding out who to listen to...
Re: finding out who to listen to...
I agree...
Re: Same
Old history
Misprint?
Re: Misprint?
cultural thing...
Shops using mostly hand tools..
Re: Shops using mostly hand tools..
Don felder's guitar...
Not a positive contribution to the discussion
Inertia and figured wood
Re: Jim, what is Osae-gani? *NM*
Osae-gani
Re: Osae-gani
Note on fitting
biases for the maker...
Re:wedge fitting
Re:wedge fitting
funny...
Re: funny...
At some point..
The experiment and conclusion are both confusing
Re: Heavy and light
another factor
If you're trimming furniture...
The best case for heavy planes...
Re: reframing the issue
Friction, and more
not the direction I went *PIC*
5 1/4
