Re: reframing the issue
Light vs Heavy planes ()
Steve Voigt
Derek,
I appreciate you bringing up the topic and laying your cards on the table. As a maker of wooden planes, I am obviously biased, so that's my disclaimer. All the same, a couple comments are in order.
First, I have a bone to pick with how you frame the issue. You define a "premium, custom" plane exclusively as an infill or metal-bodied plane. Raney did the same thing in an article that someone recently reposted on Sawmill creek. I think this is very unfair. Wooden plane makers build planes one at a time or in small batches; they are every bit as custom as the metal planes. They are made to very high standards, so they are every bit as "premium" or "high end" as the infills, even if the price tag is lower.
Second, I disagree with how you lump metal Stanley planes in with "woodies" as being "lower mass." A Stanley jack is roughly twice the weight of a beech jack: the difference is huge. The only "low mass" planes are woodies: metal planes are either heavy (Stanley), really heavy (modern copies of Stanley), or extremely heavy (infills and related).
As to the issue of which is preferable: it has to be framed in terms of the work one does. If one is merely smoothing off the ripples left by an expensive combo machine like you use, then it doesn't matter that much. But if one is doing heavy work, it matters a lot. I would suggest a simple formula: the ideal weight is inversely proportional to the amount of physical labor required. Try flattening a large table top with a no.5 followed by no.8, then try the same with vintage beech jack and try planes. I think there is no comparison, none. Though I will close by reiterating that I am biased on the topic.
Messages In This Thread
Re: Light vs Heavy planes
I like tools from Brooklyn
Re: I like tools from Brooklyn *NM*
Infills in the UK
I'm glad you commented.
Weight Comparison
more infill weights
Re: more infill weights
initial fitting...
one more follow-up comment.
Re: one more follow-up comment.
rosewood
Re: rosewood
now there is a pearl of wisdom
Re: I'm glad you commented.
what I've found...
Re: what I've found...
Re: Calling BS
Re: Calling BS
Re: Can't argue
Re: Calling BS
by the early 19th century
Re: by the early 19th century
It's not offered as ball court...
Re: It's not offered as ball court...
I'm guessing on parts here...
I miss Todd Hughes' contributions too *NM*
Re: Calling BS
Re: Calling BS
I think we're agreeing...
Re: I think we're agreeing...
Re: Me too
Wood isn't indefinitely stable, either
Re: Facts, not assertions
I haven't seen it....
Re: I haven't seen it....
Truing Kanna
expanding on what jim said
Coupla thoughts
different methods of lapping and the bump
interesting that...
Note on a modern infill
konrad's planes...
new vs. old planes...
Turnover, newbies and FAQ
comment on teaching
If you get my drift...
finding out who to listen to...
Re: finding out who to listen to...
I agree...
Re: Same
Old history
Misprint?
Re: Misprint?
cultural thing...
Shops using mostly hand tools..
Re: Shops using mostly hand tools..
Don felder's guitar...
Not a positive contribution to the discussion
Inertia and figured wood
Re: Jim, what is Osae-gani? *NM*
Osae-gani
Re: Osae-gani
Note on fitting
biases for the maker...
Re:wedge fitting
Re:wedge fitting
funny...
Re: funny...
At some point..
The experiment and conclusion are both confusing
Re: Heavy and light
another factor
If you're trimming furniture...
The best case for heavy planes...
Friction, and more
not the direction I went *PIC*
5 1/4
