Re: Ura-Dashi (tapping out) Musings
Wiley Horne--So. Calif.
Hi Brian,
I enjoyed the detailed description and level of detail and illustration you provide. A few questions:
1. Hammer. What weight hammer are you using? Is that a boat-builder's hammer, that you have ground back?
2. Ito-ura. Do you simply grind metal off the chisel, in order to obtain the very thin land? I mean, after the chisel has been prepared as you describe.
3. I couldn't follow what was going on in that picture that showed the squarish stick of wood in the middle of the ura of the chisel, with the chisel shimmed.
Thank you very much! These detailed accounts of technique are very much appreciated.
Wiley
