Re: diamond paste plate
diamond paste plate ()
John in NM
It only needs to be as flat as you want the biggest thing you will hone or flatten. So for chisels and blades, less flat needed than plane soles.
I would cut it, contamination will probably be a problem if you do not. If you plan to do some flattening, wait until after you cut it as it could move as a result of cutting.
