Mounting a chisel handle *PIC*
From Thanksgiving to Christmas was hectic in the shop building the coffee table and carving board, Christmas ornaments, etc. Before I resume the Spice Box jewelry boxes (targeted for this Christmas, didn't happen!) I am recovering by tidying up some loose ends that have been dangling for a few years to many years.
Some years ago we made chisels from CPM 3V steel. In keeping with the modernness of this steel I mounted a modern handle on one of them. One must admit the handle is striking!
It isn't a very functional handle (too heavy). I need this size of chisel for the Spice Box drawers. I make handles from Dogwood branches. The resulting handle is exceptionally tough. I have not damaged one even driving one poorly fitted one on with a steel hammer.
I turn the handle, drive a piece of brass pipe (known to the State of California to cause cancer because it has 8 parts per million lead in it) on for a ferrule and then drill a hole for the chisel slightly smaller than the diagonal across the rectangular cross section of the chisel tang, in this case 3/8". I then turned a dowel 3/8" diameter and sawed a slot down its center line the thickness of the chisel, in this case a bit more than 1/8". The two half moon dowel pieces and the steel tang are slathered with epoxy and the assembly slid into the hole and tapped to set the chisel In the hole, as shown in the picture.
The result is a handle that has proven to hold up. These chisels are multitaskers for paring and dovetail chopping and for me they do well.
Messages In This Thread
Re: Mounting a chisel handle *PIC*
It would be nice if someone...
Looks like there are tanged and bolstered
Re: Looks like there are tanged and bolstered
Re: I suspect...
Re: What a Marathon!
Re: Yeah, making kills looking for others..
Thanks for the link
Re: Thanks for the link
AMEN! *NM*
Agree and about the $80....
Re: Agree and about the $80....
Chrome Vanadium steel
Re: Those are attractive chisels...
Disagree on Two Cherries
Re: Disagree on Two Cherries
The extra labor cost would have you
Re: The extra labor cost would have you
Grain size
If "Golden Age" chisels were violins *PIC*
Re: If Will Were a Symphony Performer..
Re: If "Golden Age" chisels were violins
I left the door open
Re: Neptune's work does look nice..
All the Cartouche winners...... *PIC*
Neptune
Re: All the Cartouche winners......
Re: Grain size
Re: Grain size
Re: Grain size
Re: Grain size
Re: Grain size
Re: Grain size
Re: Grain size
Re: Grain size
Join a bladesmith forum
Re: Grain size
Re: w1 square...
Re: w1 square...
Re: Thanks for the tip! *NM*
Re: Grain size and nucleation
Re: I agree on the packing...
Book suggestion
Re: Book suggestion
Relaxation = recrystallization?
Re: Relaxation = recrystallization?
Limited attempt to answer
Re: Limited attempt to answer
Composition
Re: Composition
reply
Re: Competitions Vs. Actual Use
Agree on the knives, disagree on chisels...
Re: Place vs. need..
Certainly
good enough
Re: I agree on the ergonomics: *LINK*
David, can you put a colon after
Re: Maybe this one will be better: *LINK*
Re: Certainly
Re: Not that any of this is particularly critical! *NM*
Re: Composition
Re: Composition
Re: Book suggestion
Re: You know, I read your post so quickly..
Re: Book suggestion
Re: Grain size
Re: forging counteracts..
Hardening
Re: The weight..
Re: Cost
Re Wobbles...
Re: Re Wobbles...
Re: FWIW
Re: FWIW
Re: FWIW
Re: some links
Re: There must be...
Re: FWIW
Re: FWIW
The purpose of the half moon pieces
Re: The purpose of the half moon pieces *PIC*
