suggest frame and panel top
ian in Sydney
Hi Derek
I think the best way to incorporate a pop-up mirror in the top is to use frame and panel construction.
The mirror could then be considered the lid on a till inserted into the frame.
A solid top with an inserted mirror (= a hole in the top) is only asking for grief.
There is no reason that the frame couldn't use different widths for the rails and styles and mitred corners -- which would give you a clean look from any angle.
I'll try and do a sketch later
