Messages Archive
Another refinishing question
Keith Newton
The desk I'm refinishing has a console with tight cubby-holes for envelopes and in-out files that are too tight to use even a brush in, and if I tried to spray, I would end up getting more blow-back than what would end up in the holes.
Can the shellac which was suggested in an earlier post be thinned and wiped like a wipe on poly, or should I just go with the wipe on poly in there? The problem with that, is that some of this is open to the front, so breaking off from poly to sprayed with SWP pre-cat for the final coats becomes difficult.
