Messages Archive
OT Garage floor paint etching the floor
Mike L
Howdy. I decided to get the two part epoxy to do the floor with. Rust-Oleum Epoxy shield. I started etching the floor right after the drywallers primed the walls, and it was dry. I used muriatic acid to etch it. I opened the paint kit and it has a powered etching citrus based etcher with it. You mix it into two gallons of water and spray on. As I was reading the instructions it said do not use muriatic acid. Which leads to my question.
Did I mess up using the muriatic acid? I rinsed it twice and let it dry both time there is no flake or scale or powder on the floor. I am premiering it first to make sure all the stains are hidden.
Mike
