Messages Archive
I've had a failed switch...Response To:
You sure that wasn't a failed pressure switch? () John in NM
Stuck on after reaching pressure about 30% of the time. There is an additional pop off valve that lets go well before the tank could fail. It's loud and exciting, but not like the tank splitting I bet!
Come to think of it, saw the same effect with a two stage compressor that had a bad head gasket - second stage pressure leaked into the first stage circuit and popped the first stage pop off. That was even louder
Messages In This Thread
- Hole in air tank question
- Better Call Nall
- Re: Hole in air tank question
- Consider a Speedaire....
- You sure that wasn't a failed pressure switch?
- I've had a failed switch...
- Re: Hole in air tank question *PIC*
- Better Call Nall
