Messages Archive
wiring question
howgor
just got a samgold variable switch but I am not enough of an electrician to know the symbols for wiring it to the motor. The symbols are tilde ~with with two terminals marked AC(this should be for line power?), a circle with a M in it and one terminal marked A + and H -, and two terminals marked pw. The motor has a hot, neutral and ground wire. Not sure is the ground goes to the switch or if I should pigtail it to the ground from the line. Any help with this would be much appreciated. Thanks
