Messages Archive
Re: Using a router
Using a router ()
roger lance
By all means continue with what you are doing.....it's successful.....can't risk the matching fronts with a mistake that might have only saved you a few minutes work.
After the build it might be interesting to experiment a little with different router bits/set-up to see if you might not gain more control than you had initially. I've not had the kind of result with horizontal waste removal that you experienced.
