Messages Archive
that's the way to do it
As mentioned the pins are friction fit so they can be removed as necessary. Using my set of number drills I chose a pilot hole that provided a snug friction fit. Holes were located and drilled as you describe. I used a sized wood strip to stand in for the glass for dry fitting the battens.
