@dewalttv never quits improving their tools just like we never stop making better buildings for our clients! We are loving the new 21-degree battery powered nailer! #dewaltpartner #dewalttough
Now that we are working inside, it is time to Insulate with the @ROCKWOOLNorthAmerica and get to framing the interior for finishes!
RR Buildings Tool Belt Now Available $50 OFF for Fathers Day
https://bit.ly/4sGwX6c
RR Buildings Post Frame Plans
https://rrplans.bigcartel.com/
These are the new AugerBolts from GRK and they work amazingly. One tool! Drill the bolt thru and then tighten the nut. So easy, and a ton of time savings.
HURRY NOW. $50 off the RR FrameRR Tool Belt for Fathers Day
Sometimes you have to listen to the haters in the comments because they know more than you right? Donβt use a super sophisticated laser to level your trims! Just use a stick.
RR Tool Belt Custom designed and built for Framers!
Get your RR FrameRR Bag now with a $50 off discount for Fathers Day
Today we wrap up the exterior on the large dream garage. We get to try out some new custom trim details to help hide the concrete work. let me know in the comments if you would have done something different to hide the issues? I think it turned out pretty good and I barely notice it. Stick around to watch the interior get worked on next!
ISOtunes Hearing Protect
http://bit.ly/2PoXSBw
Get your NEW and UPDATED Sashco trial pack FREE
https://www.sashco.com/rr-buildings/
In today's episode we finally tackle the most difficult steel siding install we have ever had to do. The length and complexity of the cuts around two massive @andersenwindows at one time was tough, but we get it done. This project exterior is getting close to wrapping up.
In today's episode of building a large dream garage we continue with metal siding and installing some huge @andersenwindows 100 Series Black Fibrex windows.
Let me know what you think about the textured matte White and Black color combo!
RR Buildings FrameRR Tool Belt
First wall of steel going up on the large dream garage. We also get to start installing the @andersenwindows black 100 series windows! Man this is going to look awesome!
Donβt use cap nails! This is the big secret big cap nails doesnβt want you to know about. Save your money, and make money just using the cardboard the roll of plastic comes in!
Reviews are coming in and people love the RR FrameRR Tool Belt
Get yours Here - https://bit.ly/4sGwX6c
Big Shoutout to Phil for making this program for me to do easy math while cutting our bracing! Feels great to wrap up all of this framing so we can start moving forward with exterior finishes. Stay tuned
RR Buildings FrameRR Tool Belt Available Here
In todays video, we wrap up all of the roofing details including soffit, fascia, and ridge cap. We also took delivery of our @ROCKWOOLNorthAmerica Insulation so stay tuned for that install in the future.
RR FrameRR Tool Belt Available NOW
In todays video building a large dream garage, we get too much window to initially finish the metal roof so we work on window framing and grade board framing.
ISOtunes Hearing Protection like Kyle wears
Use Code RRB10 to save
Now this is using your brain! Leverage is key in post frame! Donβt work harder work smarter!
Pick up a new RR FrameRR tool belt and work more efficiently and comfortably. Also save tons of money when comparing to similar bags on the market!
Post Frame Building Plans
In today's episode of building a large dream garage, we finish the trusses and barely escape unscathed. This was a wild one. We were able to get a ton of work done this week and take a small break feeling good about our progress on the large garage.
Make Framing your next project easier and more comfortable with a NEW RR Buildings Tool Belt
Help Learn some of our design details and how to build your own Post Frame using our Plans as a guide and follow along with the build series
Today we start hanging 60' trusses on the large dream garage. Hanging trusses is always my favorite day. Especially when we get to play with the @magnitelescopichandlers Telehandler from RP Rents
Pick up a FrameRR Tool Belt and find out what you have been missing.
When out framing all of these large garage doors while building the large dream garage, having a proper tool belt that can keep up with you all day and not wear you out is important. Truthfully, I love how it all turned out and hundreds of others are saying the same thing! This build has a ton of work involved to get to the point of being ready to truss, but by the end of today, the large dream garage should be ready to start flying some trusses in.
ISOtunes Hearing Protection is a must
Code RRB10 to save
Can't believe we woke up to a ton of snow while building a large dream garage for our client. Nothing we can do about it, so we start framing these large walls and get to lift with the Magni from RP Rents for the first time. Man is it smooth!
In today's episode we start another build and it is going to be a Large dream garage for our client. 60x80 with 20' tall walls! This is going to be a fun one to follow along with.
Seriously, if you do any amount of layout and want perfect square every time, even with one person, check out the Stabila Layout Station, the LA180
https://amzn.to/47TinQ0
If curious about the engineered brackets we use, check out Midwest Perma Column. As far as I know, they are the only ICC rated bracket on the market. (800) 798-5562. Call ask for Dave and Drop my name! should give you discount too!
Hearing Protection by ISOtunes
Code RRB10 to save
