Use code 50ANDY to get $50 off plus free shipping on your first order at https://bit.ly/4sUTz2Z
Video with Commentary: https://bit.ly/4qeIvez
Shop Update 49: https://bit.ly/3Oe5atT
Chapters
0:00 Intro
0:05 Chapter 1: Middle Support Assembly
3:33 Chapter 2: Cutting 8" Long Tenons for Stretchers
7:25 $50 OFF Good Chop!
9:47 Chapter 2: Cutting 8" Long Tenons for Stretchers cont.
12:46 Chapter 3: Final Prep Work on Uprights
15:50 Chapter 4: Base Glue Up
18:56 Chapter 5: Bolt Holes and Table Top Register
23:04 Sneak Peak at Video 3
Patreon: https://www.patreon.com/andyrawls
Merchandise | http://bit.ly/2tXKoTr
My Amazon Store | https://www.amazon.com/shop/emilyr4life
Use code ANDYRAWLS to get 6% OFF Link๏ผElite 400 https://bit.ly/4pt0BcN
#BLUETTI #Elite400 #SolarGenerator #AndyRawls #GoAndMakeIt
Patreon Voice Over: https://bit.ly/4beOuMG
Chapters
0:00 Intro
1:13 Milling Parts
4:18 Mortises
8:03 Tenons
17:22 6" Through Mortise
19:56 Drawbore
26"04 Outro
Save 50% on your system and your first month is free when you sign up for a Professional Monitoring plan. Visit https://SimpliSafe.com/andyrawls to customize yours! Try SimpliSafeยฎ risk-free. If you donโt love it, return it for a full refund within 60 days
Shop Update #45 Big Turnings for a 12' Pecan Dining Table: https://bit.ly/4p7BQCs
Chapters
0:00 Intro
0:36 Turning the Legs
5:29 Cutting Mortises
10:53 Cutting Tenons
17:33 Glue Up
21:57 Installing Center Support
28:07 Finish
29:07 Final Setup
Save 60% on your system and your first month is free when you sign up for a Professional Monitoring plan. Visit https://SimpliSafe.com/andyrawls to customize yours! Try SimpliSafeยฎ risk-free. If you donโt love it, return it for a full refund within 60 days.
Patreon Videos
Voice Over Video: https://bit.ly/4nX0bKA
Shop Update #44: https://bit.ly/47GE9Xx
Shop Update #45: https://bit.ly/4qZMj4P
Solid Core Deep Dive:
My veneering adhesive: https://www.totalboat.com/products/clear-high-performance-21-epoxy-kits?sca_ref=3294986.OJRmY8QCyh
Chapters
0:00 Intro
1:43 Roughing Out Table Legs
4:22 Making The Solid Core Substrate
10:42 Cutting Mortises and Tapering Legs
15:28 Final Sizing the Solid Core Substrate
17:00 Making the Show Veneers
23:00 Cutting Tenons and Glue Up
26:56 Oil Finish
28:59 Installing Table Tops
0:00 Intro
1:35 Cutting Down Back and Middle Divider
6:10 Rebuilding The Top Shelf
10:15 Fitting The Top Shelf
16:01 Fixing The Dominos Mistake
Chapters
0:00 - Intro
0:59 - Bent Lamination #1 (anchor point)
6:44 - Leg Joinery (double floating mortise and tenon joint)
14:07 - First Mistake Made
19:21 - Bent Lamination #2 (bench front edge)
23:08 - Front Apron Clean Up
26:57 - Bench back
31:16 - Veneering Bench Back
35:13 - Final Back Assembly and The Big Mistake
Save 50% on your system and your first month is free when you sign up for a Professional Monitoring plan. Visit https://SimpliSafe.com/andyrawls to customize yours! Try SimpliSafeยฎ risk-free. If you donโt love it, return it for a full refund within 60 days.
0:00 - Intro
1:11 - Assembling Lower Boxes
2:52 - Face Frames and Side Panels
5:37 - Veneers for Doors and Side Panels
10:50 - Glueing up side panels for upper boxes
13:04 - Integrated Pullout Tray
16:27 - Base Moulding
18:54 - Through Mortise and Tenon Joinery
23:52 - Installing Hinges and Hanging Doors
26:45 - Integrated Pullout Tray Continoued
30:44 - Fitting Upper Doors
32:43 - Installing Applied Trim
34:58 - Pilaster Capital and Base
41:03 - Finish
43:58 - Outro
$100 off Voucher: AndyRawls100off
Expired Date: 2025.6.10-2025.8.15
US Site: https://www.makera.com/products/carvera-air
Global Site๏ผhttps://global.makera.com/products/carvera-air
Save 50% on your system and your first month is free when you sign up for a professional monitoring. Visit https://SimpliSafe.com/andyrawls to customize yours! Try SimpliSafe risk-free. If you donโt love it, return it for a full refund within 60 days. Make sure to follow us on IG: @simplisafe TikTok: @simplisafe
Go to http://thrivemarket.com/AndyRawls to receive 30% off your first order AND a FREE gift when you join Thrive Market today!
Today I'm working on restoring this 200+ year old French hutch. This is a beautiful piece, but had a few broken parts that needed fixing. Let me know in the comments if you have any ideas for what I should do with the hinges!
