WoodCentral
Normal view
I Tested the AI Robot M800Plus Lawn Mower (No Wire)… Does It Work?
15 May 2026 at 13:01
πŸ’Ύ
Check out the Yardcare mower here: https://dada.link/nqAfSd
I tested an AI robot lawn mower that doesn’t need a boundary wire β€” just a camera and onboard mapping. So… does it actually work?
In this video, I unbox and test the Yardcare M800Plus robot mower in a real yard here in Virginia. It uses a 135Β° wide-angle camera and AI recognition to detect lawn edges, avoid obstacles, and map its working area β€” no perimeter wire required.
I go over setup, charging dock placement, mowing patterns (row + random), obstacle handling, and how it performs in both open and tricky areas. It cuts well and handles slopes and objects surprisingly well β€” but there are a few limitations you should know about, especially when it comes to unclear lawn boundaries.
I Tested a Dehumidifier in My Workshop for Several Days - AlorAir Helios MP55
10 May 2026 at 13:00
πŸ’Ύ
AlorAir Helios MP55 dehumidifier: https://bit.ly/3OnPswY
5% off discount code: YTDarbinOrvar
After noticing the workshop sitting at around 55% relative humidity, we started looking into what that actually means for tools, wood, machinery, and stored materials. Turns out, humidity can quietly cause a lot of damage over time β€” rust, swelling, mold, warped wood, and ruined projects.
In this video, we test the AlorAir Helios MP55 dehumidifier in a real workshop environment over several days. We log humidity and temperature data every 5 minutes using an ESP32 setup, track how quickly the humidity drops, and take the machine apart to look at the internal construction and build quality.
In this video:
β€’ Workshop humidity testing
β€’ Real data logging over multiple days
β€’ Dehumidifier performance results
β€’ Full teardown and internal inspection
β€’ Pump drainage setup
β€’ Thoughts on noise, build quality, and usability
The workshop dropped from around 55% humidity to the mid-30s and stayed there consistently during testing.
Thanks to AlorAir for sponsoring this video.
Check out the shoppe: http://darbinorvar.com
Become a patron: http://patreon.com/darbinorvar
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
How to find Darbin Orvar
http://twitter.com/darbinorvar
http://instagram.com/darbinorvar
We Built a Custom Book Box with The Aliencell X1
26 March 2026 at 13:00
πŸ’Ύ
Spring Sale Promo Code: https://shop.aliencell.com/?ref=DARBINORVAR
Aliencell X1: DARBINORVAR 20%OFF
Add-ons: DARBINORVARACC 5%OFF
Promotion Period: PDT March 27– March 31
Building a book box with a 60 watt laser!
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
Move Your Solar Panels Anywhere β€” DIY Portable Solar Cart
24 March 2026 at 13:17
πŸ’Ύ
Let's build a portable solar cart so we can move the solar panel wherever we need them.
RENOGY SPRING SALE IS LIVE NOW! Up to 33% OFF site-wide!
Browse the full Renogy Spring Sale: https://dataaccess.renogy.cn/t/bG
Check out the Shadowflux here: https://dataaccess.renogy.cn/t/YG
Thanks for watching!
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
How to find Linn @ Darbin Orvar
#Renogy #RenogySpring #Shadowflux
I Replaced 2 Security Cameras With 1 – Here’s What Happened
23 February 2026 at 14:59
πŸ’Ύ
I tested a dual-lens outdoor security camera to see if it can truly replace two separate cameras. Here’s how it performs in real-world use β€” setup, tracking, solar power, and whether it’s actually worth it.
πŸ›’ Shop the TP-Link Tapo C645D KIT Camera:
Amazon: https://bit.ly/3Zp3P62
Official Site: https://bit.ly/4tqqFYW
πŸ’Έ Lowest price at launch: under $150
🎁 Grab the new camera and get a free trial of the latest Tapo AI Assistant.
0:00 – Testing the dual-lens concept (can it replace two cameras?)
0:38 – Unboxing: camera, mount, solar panel
1:00 – Setup process (app, Wi-Fi, SD card)
1:27 – Installation & placement
3:27 – Dual 2K lenses explained (wide + pan/tilt)
4:32 – App controls: alarm, pan/tilt, two-way talk, lights
5:52 – Real-world tracking & patrol mode
6:53 – Multi-day review & performance
7:53 – Maintenance & storage (solar + SD overwrite)
8:21 – Who this system is for
8:58 – Final thoughts & link
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
#Tapo #TapoC645DKIT #TapoDualLensCamera #TapoSolarCam
Traditional Bookbinding Using My DIY Tools
21 November 2025 at 14:33
πŸ’Ύ
Making a notebook using my handmade bookbinding toolsβ€”press, vise, sewing frame, and plow. Simple steps, traditional methods, and a few tips along the way.
Make your own bookbinding equipment: https://www.darbinorvar.com/bookbinding
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
The Solar-Powered Security Camera With No Subscription // Tapo C615F Tested!
7 November 2025 at 14:46
πŸ’Ύ
Check out this floodlight security camera if you're looking for something affordable that works without wires and easy setup.
πŸ›’ Shop the TP-Link C615F KIT:
Amazon: https://bit.ly/49xHQ32
Official Site: https://bit.ly/4938tg1
Best Buy: https://bit.ly/3JgKJe4
πŸ’Έ Use code 10TAPOFLDCAM for an extra discount
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
#TPLinkPartner #Tapo #TapoC615FKIT #TapoFloodlightCamera
I Tested a CHEAP Robot Lawn Mower β€” No Setup Needed! β€” Yardcare V100
13 October 2025 at 13:44
πŸ’Ύ
In this video, I test the YardCare V100 β€” a budget-friendly, camera-guided robot mower that claims to handle up to 1,600 sq ft with no setup or boundary wires. I go over ease of use, performance, features, and overall value for the money.
Link: https://dada.link/deQFbi
There is a $130 off coupon on page and you can also save 6% at check out, so the final price will be $339.99
Chapters:
0:00 Intro
0:30 Specs & Features
2:00 Design Overview
4:00 Setup & First Test
6:00 Performance & Battery
7:00 Pros, Cons & Verdict
Mailing Address:
Darbin Orvar
PO BOX 1101
Goochland, VA 23063
